vcMultiDriverTarget
An object with properties to define necessary information to plan and execute a multi-driver motion.
Module: vcRobotics2
Parent: vcMotionControllerTarget
BlendingTypevcMotionBlendingTypeRWGets or sets the desired blending type. Also see BlendingValue.
BlendingValueRealRWGets or sets the value that defines how early blending towards the next motion may start. Also see BlendingType.
ExternalDriverValueslist[tuple[Integer, Real]]RWGets or sets the list of external driver values to reach at the end of the motion. The integer is the external driver's index in this controller.
InternalDriverValueslist[tuple[Integer, Real]]RWGets or sets the list of internal driver values to reach at the end of the motion. Not used for vcPtpTargets.
MotionTimeRealRWGets or sets a time for the motion in seconds.
When > 0, the time to reach the target will be forced to this, ignoring limits. Otherwise, the time will be determined by the driver limits and the distance to the target
VelocityPercentRealRWGets or sets the desired velocity percentage as decimal value [0, 1.0].
